17-09-2016, 08:08 AM
I posted regarding this issue basically I had person/mechanic install a clutch
The install or part ! Has failed result clutch failure after 70miles
It's been a headache from the start but I'm asking for Opinion on this bearing
He claims bearing was separated when he removed clutch .
Should the bearing be pressed and not separate ? What's required to separate ?
On the bearing are some rather flimsy looking locator tabs , the bearing can only be installed the correct way due to the rectangular locator . The bearing now has only one locator and there's some evidence of chaffing
Would a poorly seated bearing prevent the clutch engaging ?
What's your view on the part condition ?
He's now asking I pay for job again
I ordered the part and I did this to ensure it was correct , it was done by obtaining part numbers from vin @ dealer parts department .
Your thoughts and opinions plz
