Threads: 30
Thanks Received: 13 in 8 posts
Thanks Given: 2
I need new winter tyres for the coming winter. Was looking at fitting 205/65/16 will give me extra 15cm on the diameter. Is anyone running this size or larger? I want to go larger if possible as I figured this will be a good way to give me slightly higher ride height to get through the drifts etc.
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 4
I upsides from 175/70/14 to 184/65/14 when I bought my Winter tyres.
Can recommended the Nexen Winguard Snow G WH2 tyres.
Silver Berlingo Multispace 1.4i Forte
Threads: 6
Thanks Received: 3 in 2 posts
I'm running 195 x 65 x 15 winter tyres. On my Partner, no problems, arches look full.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
205/65/15's will only give you approx 6mm height difference over your 195/65/15's, that's hardly going to make a difference.
Threads: 0
Thanks Given: 3
You're right, though I'm actually on 195/60 R1 by mistake ( happened when buying part worns...) so I'd get a bit more than that.
I've also got an issue beneath the van that makes me want to increase clearance in any way until I fix it.
Threads: 8
Thanks Given: 305
37
Try using a tyre size comparison tool to see the difference in sizes.
https://tiresize.com/comparison/
