Threads: 3
Thanks Received: 5 in 3 posts
Thanks Given: 3
i say photo 1 but try it on there is only 1 way if you get it wrong then it wont touch the flywheel .
Threads: 3
Thanks Given: 3
im not shore either man seeing those 2 photos is confusing .
Threads: 9
Thanks Given: 316
15
It should be marked flywheel side on the driven plate
Threads: 20
Thanks Given: 2,126
18
The flat side goes to flywheel.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• Jayward
Threads: 4
Thanks Given: 2
Second picture ?
Your right it it should be marked !! But now he's fully bled back from slave , can he back bleed from pedal ?
However he's saying fork has full travel and even with force on the fork !! It's not engaging , it's not lifting plate off ...
From chats I've had its seems it should be fitted like second picture
Ron are you saying the same ( it looks like he's installed plate wrong way around )
I'm thinking the same about windows !!
But I need to tell him confidently it's in wrong m8 !!
He says auto-data picture shows different
I wana walk in Monday and say ya have f,d it fix it ASAP
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
Is it the right clutch plate ?
definitely not No1
No 2 looks confusing to me with the centre spline sticking out .
Threads: 29
Thanks Given: 67
20
22-09-2016, 08:01 AM
(This post was last modified: 22-09-2016, 08:04 AM by ffrenchie.)
The nose faces out so picture 2 is wrong. Your picture is confusing, the flat side goes to the flywheel and the nose points out to the thrust bearing side.
