Door grab handles
Both my front inner door grab handle trims are worn and the grey paint has worn off revealing the black plastic. Has anybody replaced, painted, come up with a fix?
I have tried wrapping in carbon fibre vinyl but no success too many contours?
Any ideas?
2009 XTR
I finished mine just yesterday.
Sanded the handles down a bit, where there were dents etc. Grey primer, 3 coats of BMW Space Grey, 3 coats of clear lacquer ( all from Halfords).
Looks really good, esp. compared with before.
Attached Files Thumbnail(s)
[-] The following 1 user says Thank You to eSPe for this post:
  • Jelevents
(18-09-2016, 05:44 AM)pompuras@gmail.com Wrote:  I finished mine just yesterday.
Nice Job, looks realy nice
BTW can you please post the procedure to take the handles off (maybe photos if you have any) and if there are any "watchout" for to take them off without breaking anything..........
I am sure alot of the members of the forum are suffering from this who can benefit
Thanks in advance
Removing handle is very easy.
There are just clips holding the handle, no screws. I used thin flat screwdriver wrapped around with some sellotape to prevent scratches. I slided the screw driver where the A is on the picture, pulled and then worked the way around the handle.
I forgot to mention, the inside handle bit, that you use to open the door, was quite worn as well. I just sanded it down to black plastic, and used this:
http://www.halfords.com/motoring/car-cle...-wax-375ml
to make it look black.
I am about to spray all grey interior bits so will post more pictures once finished.
Get yourself a set of like these to remove trim and panels without scratches or damage http://www.ebay.co.uk/itm/5-Piece-Car-Do...SwxehXOfW0
They save a lot of swearing.
  • eSPe
Nice one looks very neat, that might be the way to go, thanks
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
