Threads: 7
Thanks Given: 5
I'm about to flush all the coolant out of the Berlingo. Does anyone know how much coolant is needed to replace the old one?
Also, has anyone flushed the system out with water? Any tips or advice would be appreciated.
Thanks.
Threads: 9
Thanks Received: 26 in 21 posts
Thanks Given: 19
Which engine?
Sent from my SM-G925F using Tapatalk
Threads: 16
Thanks Received: 41 in 18 posts
Thanks Given: 1
8
hi
Priority is getting the Matrix sorted especially with the Winter Months ahead No point in refilling with antifreeze if you still have a leak.If frost gets to the matrix before you do it will expand and cause a real problem.
Sorry just looking at potential problems
"Communication is the Key to everything"
