corrosion engine bay
Hi
Does the M59 - 2005 berlingo suffer with corrosion in the engine bay and under bonnet edge lip,
i have had to rub down inner bonnet where it secures and left hand engine bay give it red oxide and paint it black.
do i need to worry about the rust under the bonnet and in the engine bay?
Mine is the very light blue colour, does anyone know the code for this colour to help match touch up paint?
any advice greatly welcomed
many thanks
The paint code should be on a plate on the passenger side under the bonnet near the battery
"Communication is the Key to everything"
[-] The following 1 user says Thank You to Pdamo for this post:
  • haveagoamigo
waxoil is you friend
  • ron
Totally agree with Polar Waxoyl is a Must
(25-09-2016, 09:28 AM)Pdamo Wrote:  The paint code should be on a plate on the passenger side under the bonnet near the battery
Many thanks
(25-09-2016, 09:45 AM)polar Wrote:  waxoil is you friend
I've used it for donkeys years.Squirt into seams first.Thin in cold weather & put two or more coats on.Mix with underseal for "wear" areas.
Ron there is another product worth a mention the body shops use it when they do a repair to doors or sills its called, Wurth Cavity Spray
http://www.ebay.co.uk/itm/like/310971816...460&crdt=0
It is very good for doors and sills - it is very thin and runs into the smallest of gaps
[-] The following 2 users say Thank You to polar for this post:
  • haveagoamigo, ron
thanks for the info. Greatly appreciated
Lots of products around these days and one I have been impressed with is Dinitrol !
  • haveagoamigo
great thanks
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
