[Engine] will not start from cold
I have an ongoing starting issue with a mk1 1999 berlingo van, 1.9.
The glow plug relay has recently been replaced, along with the glow plugs, but it will not start from cold, one squirt of easy start, and its away, and once started will start fine for the rest of the day, but the following morning, will not start from cold, anyone any ideas please?
Did you fit decent glow plugs or ebay specials?
If its high milage it could be valve clearances.
Easy start will blow the ends of your glow plugs!
(25-09-2016, 12:37 PM)polar Wrote:  Did you fit decent glow plugs or ebay specials?
They were from ebay, so this is a potential problem? it is very high mileage, plus 220k and the easy start has only been used a couple of times, the vehicle isnt actually on the road atm
Ive seen ebay specials before 1 out of 4 working!
First things first go to europarts or GSF and get a decent set of Beru glow plugs.
Or remove the glow plugs and check on a battery = easy check - take into account time to heat up + do they get white hot at the tip not just red.
Just a couple of times can be all it takes if you are unlucky - think about it hot glow plug coming into contact with a highly explosive gas in an enclosed chamber?
Starter motor ? May be it spins ok.but they do wear out slowly
(25-09-2016, 12:53 PM)polar Wrote:  Ive seen ebay specials before 1 out of 4 working!
hmmm, ok, i will give that a try, did have an aa guy to look at it, and he tested the relay, and confirmed ok, but given how easily it started with easy start, and i do mean immediate, he seemed to favour the engine mounted pump, but i will give glow plugs a test, thanks for your help
(25-09-2016, 01:00 PM)Johny555 Wrote:  Starter motor ? May be it spins ok.but they do wear out slowly
something else to think about! thanks for the suggestion, it does seem to turn over pretty well, and is very close to starting
Any air leaks into the fuel pipes will cause bad starting after sitting overnight . Favourite culprit is the fuel filter lid not seating properly.
  • ehill42315398
(25-09-2016, 02:14 PM)brodfather11 Wrote:  Any air leaks into the fuel pipes will cause bad starting after sitting overnight .  Favourite culprit is the fuel filter lid not seating properly.
This has been happening for a few weeks, i have just replaced the fuel filter, but will check again, thank you for your help
had this problem on mine,
Valve clearances, tappets re shimmed, problem solved.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
