26-09-2016, 06:25 PM
I have a weird problem on my 2002 1.9 Non Turbo Berlingo
The car has always been slow and lacking go,But periodically I get a surge as though an extra cyclinder or turbo has cut in
If the car would always perform like this I would be delighted.
I have changed fuel filter blown out the air filter and had a mechanic friend check for vacuum and obvious leaks.
Only other maybe related issues are . The car seems to run out of fuel when fuel gauge is nowhere near the redline .Aftertopping up all is well. The car shows no other signs of fuel starvation It goes up long draggs slowly but no cutting out or white smoke
Engine ticks over and does not hunt> I got the car seeing it had a tow bar fitted .I was hoping to pull a motor cycle on a trailer but It does not have enough power to maintain any sort of reasonable speed
Thanks in advance for any thoughts
