[Engine] Which is right Battery ?
I think my battery is on it last legs so decided to buy a new one. . The problem is there is two batteries that I can buy both Exide Brand
(1) EA640 ( Capacity 64 Ah)  Cold Test  ENA 640  @88 euros
(2) EB620  (capacity 62 Ah   Cold Test   ENA 540 @82 euros
Is it worth paying the extra 4 euro for the EA640? and is this the right battery as the battery on the car now is very small  (20cm) compered
to the ones listed above which are 24.2cm  although there seems to be space for them to fit.
Get the biggest amp battery you can
As above ^
(27-09-2016, 05:43 PM)polar Wrote:  As above ^
Since my listing I have come across another battery . . .096 Enduroline Car Battery 80Ah 780CCA  which is listed for the 07 1.6hdi Berlingo on the website  but not sure about the make but has very good reviews so would this be a better buy?
https://www.tayna.co.uk/096-Enduroline-C...P8383.html
Sounds OK,good amps,
Its all about the Ampere hour AH and the cold cranking amperage CCA The higher the numbers are the better/stronger the battery - always buy the best biggest AH & CCA you can get for your vehicle - if you plan to keep the vehicle anyway.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
