Thick black smoke
Hi I'm having problems with my 2010 1.6 hdi Berlingo van it has 90 k on clock and has recently started smoking after having injectors cut and reseated I haven't lost any power and economy seems OK there is no management light on and when it's just ticking over there is no smoke at all any ideas please
Sent from my SM-A300FU using Tapatalk
Put Somme injector cleaner thew it,see how it goes,if losing no power can't see it being turbo,
Already done the injector cleaner no difference did notice a slight oil residue on the spigot from the turbo but I really don't know much about engines at all , its booked to go into a garage on Tuesday if there's oil going through the turbo would this cause black smoke?it does become worse at about 2500 rpm is there any way oil can get into the turbo and if so how .thanks
(29-09-2016, 07:04 PM)Johny555 Wrote:  Put Somme injector cleaner thew it,see how it goes,if losing no power can't see it being turbo,
Already put injector cleaner in, put further information in another reply sorry I'm new to this site thanks
Check your air filter is clean and no obstructions in inlet. Were the same injectors refitted and why were they taken out? Did you remove all the old copper washers and replace with new? (Ie didn't leave an old one in and put a new one on top)
(29-09-2016, 11:03 PM)Col Wrote:  Check your air filter is clean and no obstructions in inlet. Were the same injectors refitted and why were they taken out? Did you remove all the old copper washers and replace with new? (Ie didn't leave an old one in and put a new one on top)
No col the garage said they put new washers I'm starting to think that the problem was already present but due to the bad seal the on one of the injectors the compression was low in one of the chambers and now it's sealed it's blowing back into the engine and could be a bad piston ring although it turns over first time every time,I took the oil cap of the head and theirs a lot of pressure blowing back is this likely that it could be a piston ring?and if so how can I make sure and how easy a fix is it?
Go first with compression test. If it is bad , find out where it is leaking
with cylinder leak down test. Then post your findings here on forum.
Best regards,
brajomobil
Best regards,
brajomobil
OK thanks gives me a better idea when I'm talking to the mechanics
Chuffing out of the filler is normal, but as brajomobil has said, a compression test will confirm.
Black smoke is incomplete combustion, ie, too much fuel or not enough air. Did you have the injectors tested while out? A common smoke issue is caused by too thick or too thin amount of copper washers as it changes where the injector sits in the head (how deep or shallow the injector sits) which alters where the fuel sprays into the piston combustion chamber.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
