Slight smoke/steam coming out the engine area
Hi.
I mentioned earlier how my heater matrix is leaking, so this post is kinda related to this.
Sometimes when I stop at the lights, and when the sun is out, I usually see faint wisps of steam coming out the sides of the bonnet's gap. Is it possible that it's the coolant being burnt off, or could it be something else? I know I have a slight oil leak, so not sure what to make of it?
Thanks.
How much Fluid and Oil are you Losing?
"Communication is the Key to everything"
Both oil and coolant really, but it's a slight amount (not much).
Just a couple of things to check
1. Any white gunge in the oil filler cap
2 any gunge in the expansion tank
A lot of the problems are related to gunge in the cooling system which blocks the matrix and causes back pressure problems.You really need to flush the cooling system but also back flush from the matrix to the radiator. I normally do this after I have drained the system .
Check these points and let us know
(02-10-2016, 10:22 AM)dingleberryblue Wrote:  .... Sometimes when I stop at the lights, and when the sun is out, I usually see faint wisps of steam coming out the sides of the bonnet's gap. Is it possible that it's the coolant being burnt off, or could it be something else? I know I have a slight oil leak, so not sure what to make of it?
Thanks.
You can sometimes see steam coming off the radiator from any moisture (rain / condensation) trapped within the fins of the radiator.
Yesterday 10:47 PM
Yesterday 09:14 PM
OIL Drip
Last Post: Martinze
Yesterday 06:08 PM
Yesterday 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
Yesterday 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 09:32 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
