drivers airbag warning light fix
Failed MOT on various things, including airbag light staying on - again. Tested drivers airbag circuit using a variable resistor box, which simulates the airbag (which I had very carefully removed). The airbag light stayed off with resistances from 0.3 ohms to 3.9 ohms. I noticed while I was testing that the airbag ribbon cable was bent at a sharp angle about 7 notches down from the airbag connector. I reshaped the ribbon cable from the connector past the sharply bent section into a gradual bend, so there were no sharp angles, and carefully connected the airbag and replaced it on to the steering wheel. Airbag light now goes off every time I start up.
Good to know thanks
"Communication is the Key to everything"
Timing belt change interval
Today 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
