Rear lights
Hi there. I need to replace a rear light on my '04, if I get the '08 crystal lights do I need the bulb holders as well or will the lenses fit?
I'm aware that you can't mix van and hatch lights, found some crystal van lenses for peanuts so I may as well update it while I'm on!
Cheers in advance.
(03-10-2016, 12:24 PM)tomoguchi Wrote:  Hi there. I need to replace a rear light on my '04, if I get the '08 crystal lights do I need the bulb holders as well or will the lenses fit?
Cheers in advance.
The lenses will fit. You need not replace the bulb holders - I know that coz I've done that myself and observed that they use the same holders.
Took a punt anyway after some brief googling but can confirm they do swap over as I fitted them in my lunch break at work Big Grin
Cheers for the reply, add it to solved!
Post a picture then so we can see what they look like  Undecided
[Image: 542e018e95b3565ca19e5b834c2e0766.jpg]
I'm happy with that, it's lifted the look of it no end!
[-] The following 1 user says Thank You to tomoguchi for this post:
  • jj9
(07-10-2016, 09:52 PM)tomoguchi Wrote:  [Image: 542e018e95b3565ca19e5b834c2e0766.jpg]
I'm happy for you.
The crystal lights do look a bit more modern  Cool
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
