Double Din Install
Threads: 3
Is it possible to take out this compartment below the stereo and install a double din unit???
[Image: pict0276r.jpg]
Threads: 80
Thanks Given: 25
what model of berlingo is that?
2010 artic silver VTR with EXTRAS.......  unny:
Threads: 3
(09-10-2011, 08:28 AM)pch Wrote: what model of berlingo is that?
Mk3
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
From looking at your picture it shouldnt be a problem, only thing is where would you put the aux socket, i would also recommend taking it out first just to see how much clearance you have got behind it as well
Threads: 3
(09-10-2011, 02:58 PM)BerlingoHDI Wrote: From looking at your picture it shouldnt be a problem, only thing is where would you put the aux socket, i would also recommend taking it out first just to see how much clearance you have got behind it as well
that picture isnt of my dash, just one i found on google that looked similar, mines a right hand drive and has no aux socket.
Threads: 28
Thanks Given: 29
Threads: 20
Thanks Received: 57 in 41 posts
Thanks Given: 33
I've been thinking about doing this with my XTR.
I'd like to fit a double-DIN satnav/dvd player in,but,I'm wondering how you are supposed to use and,or,reset the lcd display on the top of the dashboard.
To set the time and date on the display has to be done via the radio.
I know there are aftermarket connectors,but is it still possible to adjust the display with another radio/dvd/satnav system?
Threads: 20
Thanks Given: 33
The cubby hole below the stereo just pulls out,I had mine out last weekend,there's acres of room behind it.
I was going to swap the radio/cubby hole around,but can't find my radio removal keys,so I'll have to buy some new ones.
Threads: 147
Thanks Given: 263
11
25-01-2012, 03:45 PM
(This post was last modified: 25-01-2012, 03:46 PM by Andre.)
(25-01-2012, 03:30 PM)XTR Wrote: The cubby hole below the stereo just pulls out,I had mine out last weekend,there's acres of room behind it.
Don't buy, if they are anything like the ones on the MK2 its just a case of needing 4 long nails (not the finger type), and out it comes with no damage. (Me being tight. I had 4 nails in the garage so it was ideal for me). I'm interested to know if there is a way to preserve the data that is displayed on the multifunction display. I can't see it being possible to alter settings from a third party stereo; but i will try to find out an alternative/answer.
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• XTR
Threads: 20
Thanks Given: 33
(25-01-2012, 03:45 PM)Andre Wrote: (25-01-2012, 03:30 PM)XTR Wrote: The cubby hole below the stereo just pulls out,I had mine out last weekend,there's acres of room behind it.
Most of the display functions work off the end of the wiper stalk,it's setting the time and date that will present a problem as that is done via the factory radio.
Are Citroen radio's made by Clarion?
It seems that a lot of factory fitted radio's are,the Volvo truck ones certainly are,and I think I read somewhere that Citroen are too.
M59 1.4 Petrol question
Yesterday 10:48 PM
Yesterday 09:29 PM
» Replies: 27
Last Post: MariusTeamPP
Yesterday 07:01 PM
Yesterday 09:08 AM
Insurance Shocker !!!
Yesterday 09:04 AM
13-03-2025 08:09 PM
How rare is my berlingo
Last Post: Gadgetman
13-03-2025 02:30 PM
Official Citroen internal child monitoring mirro...
13-03-2025 10:31 AM
Anti corrosion spray
12-03-2025 02:35 PM
Rubber pipe in engine bay
12-03-2025 10:16 AM
