  • 1 Vote(s) - 2 Average
unsucky suckers for thermal blinds
hi
I bought a set of foild backed thermal windscreen blinds for my berlingo conversion. problem is the suckers are so awful I'v given up and am using a curtain instead. The suckers are very stiff and dont want to stick to the windows, the colder the night the worse it is. I'd like to replace them with some suckers that work - can anyone suggest anything? A frined of mine got some good ones off ebay, but cannot for the life of him remember the name!!!! Huh
I had a similar problem using a dash Cam sucker I solved the problem by using a clear "Hair Gel" works works fine
[-] The following 1 user says Thank You to iscom for this post:
  • knownowt
EBay, window suckers,,
http://www.ebay.co.uk/itm/10-PACK-40mm-T...SwnLdWp7vv
French Electrics......Grrrrrrr! Dodgy
[-] The following 1 user says Thank You to Sootyfoot for this post:
  • iscom
(10-10-2016, 07:17 PM)Johny555 Wrote:  EBay, window suckers,,
yeah, but what sort? no point buying the same crappy ones again!
Put some little squares of self adhesive Velcro (or other proprietary brand of hook and loop fastener) in the corners of the window they shouldn't be too intrusive.
  • knownowt
Adhesive Velcro got to be worth a look ?
i'd just go with cheap suckers off ebay and hope they are a bit more flexible, the ones linked to above are fine, (I use them on 2 screens i made for the rear windows on my barn doors) but im not sure they would fill the holes in your screens without a peny washer or similar...
(10-10-2016, 05:07 PM)peri Wrote:  hi
Where did you get your blinds?  am currently searching for suitable blinds for peugeot partner  which I think has same windows as berlingo -- want something for all windows -- prefer to buy rather than make as not sure of my skills in making ...but not having found any -- I may have to resort to making.  Suckers seem quite expensive for decent ones and have had problems in past on other vehciles with them not sticking very long.  Any advice welcome
Smear a little vaseline around the outer edge before you put them up. When you push the sucker on to the window you push the air out and the vaseline creates a seal that stops the air getting in. Make sure the window is clean before you put them up.
1.6 hdi turbo fail again advice please
Last Post: cancunia
Today 02:49 PM
» Replies: 29
Headlights staying on
Last Post: cancunia
Today 12:17 PM
M59 Cruise Control Stalk (not speed limiter)
Last Post: cancunia
Today 12:09 PM
B9 tuning update
Last Post: northroadycles
Today 08:38 AM
Steering wheel?
Last Post: alavya
Today 07:18 AM
Brake switch location on 2013 automatic Partner
Last Post: eSPe
Yesterday 09:26 PM
MY PARROT CAN'T TALK !
Last Post: karma846
Yesterday 08:36 PM
all weather tyres?
Last Post: SayAnything
Yesterday 06:25 PM
I am selling my beloved Berlingo
Last Post: suewills
Yesterday 10:00 AM
Last Post: Grizz
Yesterday 08:30 AM
» Replies: 560
