  • 9 Vote(s) - 2.56 Average
Radio Cassette Removal
Hi I have an X reg and i believe it has the original radio cassette which i wish to remove. How do i do it .
Thanks a lot
Stephen
(09-10-2011, 01:45 PM)quantockman Wrote:  Hi I have an X reg and i believe it has the original radio cassette which i wish to remove. How do i do it .
Thanks a lot
Stephen
You should have 2 u shaped pieces of wire that you push into the holes non either side of the radio to release the clips. The radio the pulls out far enough to disconnect the power and aerial cables
Thanks a lot
Stephen
Thank you. Will give it a go tomorrow, there are two holes each side does it matter which ones i use?
Thanks a lot
Stephen
you need to put something in all four of holes to release the locking legs,four small screwdrivers or a piece of welding rod bent for each side,the real tool is only about £2 on e bay or halfords
[-] The following 1 user says Thank You to walneyisland for this post:
  • quantockman
Romahomepete,
Thank you for all your help. I now have music as i trundle......i think cool jazz suits its style
Stephen
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
