My Berlingo Camper build.....
Hi folks,
I've been posting in the wrong section.......
http://www.berlingoforum.co.uk/thread-13212.html
Anyways, here is where I'm at today.....I'll update this thread !
In the begining, New to me, Berlingo Multispace........Plan is for Micro camper Smile
[Image: 29pufjm.jpg]
After some chopping about
[Image: e0r6er.jpg]
[Image: 2zgvx45.jpg]
Some progress
Floor down, bed frame made, mockup in ply and framing of hanging space, sink, cooker unit. This will used as my template, unit remade in 15mm furniture board, electric (12 and 240v will be ordered today.....)
[Image: 2zg979j.jpg]
That was the prototype, now the production version Smile
Getting there slowly, (my work process involves doing everything at least 3 times , usually not intentionally Smile ) Just the wiring to hook up now and the soft furnishings
[Image: 2hZTV.jpg]
[Image: 2hZTW.jpg]
[Image: 2hZYL.jpg]
Sleeping bit is 25mm angle frame, 12mm ply platform and 15mm furniture board lining. Wiring is all in, now needs connected up, gas connection tonight, (hopefully no bonfires......)
WOW, that is exquisite workmanship. Wish I had your skills. Very well done indeed.
Excellent stuff mate you should be proud of what you have achieved as much as I am impressed!
And then there was light.......And water, and gas !!
All systems now hooked up and working Smile multiple USB charge points, couple of volt meters and a cig lighter type socket. LED lighting, separate switching for each side....Couple of 240v sockets if needed on hookup
Split charge works as well Smile
Now the soft stuff.
[Image: 2dhgrxs.jpg]
[Image: 2m5ypts.jpg]
[-] The following 1 user says Thank You to 48pop for this post:
  • knownowt
Wow great stuff, what a dream making machine.
Absolutely Great Stuff.
You must be Very Proud of what you have achieved. Well Done
im loving it!
French Electrics......Grrrrrrr! Dodgy
That is class! where did you get the tilt-up roof?
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Very nice top work . Cool
Awesome! Looks similar to what I'm planning for mine, minus the side windows. What split charge system did you use, may I ask? Also how easy was it to cut the gas vent hole in the floor? Did you use a hole saw?
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
Last Post: jw4821
20-04-2026 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
