[Engine] Emergency: Engine Mount Bolt Size?
Exclamation
Hello!
I need to know the bolt size that is on the top engine mount of my Berlingo 2004 FA Petrol.
In the picture it is where the red arrow goes (the blue one's is just to show where the rest are)
Thanks in advance!
The reason why i am looking for it is because probably the previus owner missed to put it back when he changed the timing belt...
//BR
Patrik
Sorry no idea, have you tried using one of the others to see if it fits. This would give you a bit of a clue.
Citroen or Peugeot dealer. Then you know it will be right.
(12-10-2016, 10:41 AM)Trevor Wrote:  Sorry no idea, have you tried using one of the others to see if it fits. This would give you a bit of a clue.
The engine is still in the car so I dont think i can loosen the others.
(12-10-2016, 10:54 AM)Col Wrote:  Citroen or Peugeot dealer. Then you know it will be right.
True, I'll try to call them to see.
//BR
Patrik
Got an answer now.
Its a m10 150-77
I think tho, that the old one is still in the block. what is the best way to take it out? drill it and then make some new threads?
I'vent taken the engine mount away yet. What would be the best way to do this with the engine still in the car?
Put a hydraulic lift under the engine and then unscrew the bolts or what do you think?
Depends what access you need. If bolt has sheared flush- weld a nut onto remains of old bolt and undo. If you need to drill it out, you probably want the engine out for access to see what you are doing.
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
