belingo alternator
hi , yesterday my battery light came on for a short period then went off ,this morning came to start it and dead, nothing at all, charged battery  put tester across battery with engine running and only showing 11.69 volts so not charging the battery has only recently been fitted  .Cleaned connections and still no joy , right next to the alternator there is a  thin purple wire with a bare end obviously broke off from somewhere, has anyone  any ideas where it goes and could this be the cause of my trouble ? ive downloaded a pic of what seems to be my alternator and i can see 2 little prongs next to the main terminal ,would it go to one of them ? any advice would be greatly appreciated Rick H
Is the other end still on the alternator?,
Hi Johny555, no i can actually see the prongs ,so if there was a connector there its worked loose and broke off ?
Just looked at mine,theres a purple wire and a green wire so looks like that little plug has snaped off yours
(12-10-2016, 12:24 PM)Johny555 Wrote:  Is the other end still on the alternator?,
opps sorry resent original reply
Hi Johny555 thanks for the quick reply , so i need the connector then and will this solve the problem?
You can try ,u need it any way,get that first before getting new alternator,
I looked at my 2001 berlingo, yours must be a later model than mine. I have a screw terminal where your pic shows a plug in one. The wire on mine is a green coloured one. this wire should have 12 volts when ignition on to make the alternator work .
thanks for the quick replies guys , now where can i get the plug
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
