Threads: 8
Thanks Received: 7 in 6 posts
Thanks Given: 2
So i'm back again with a new problem.. My 1998 berlingo van with the 1.9d engine had a new (used) alternator installed last year after it stopped charging properly. That fixed the problem that time.
A few days ago the battery lamp started coming on again and it stopped charging. The lamp has been coming and going somewhat but mostly it is on and not charging. So I went to get another used alternator supposedly from a very low mileage van. I fitted it like last time and started up but the battery lamp is still there and not charging!
I have tried running wires from alternator ground and battery ground. Also from alternator plus to battery plus. Both to check if a bad connection was the problem. Now I don't know where to go from here. Du you guys have any idea what could be wrong?
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
12-10-2016, 07:20 PM
(This post was last modified: 12-10-2016, 07:22 PM by Johny555.)
Go get a new alternator,2nd hand is a waste off time mate,,course they will tell its off a low milage van,there not going to say its off a high miler are they,check bottom pully as well ,the belt might be sliping
Threads: 8
Thanks Given: 2
It just seems strange with 2 broken alternators. They wouldn't sell me a broken one knowingly as they offer a warranty on the parts. It would be a freak coincidence. Alternators don't break THAT often.
Pulley and belt is ok. Tight and not slipping.
Thanks Given: 8
5
Best way round it is just get a new one,their not that expensive, and it saves all that messing about,that's just my opinion,
Threads: 67
Thanks Given: 238
50
On an alternator the brushes usually wear out and any other problems sit in the " rare event " category.
Brushes typically come complete with the diode pack rather than separately and I would fit a set to the " new last year " unit and go from there. They are easily fitted, well I think so anyway and not expensive either.
I naturally assume you will check the condition of the commutator before parting with your hard earned .........
Serieal Berlingo owner
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
I'm with Jonny on this. Fit new, and you have a proper warranty.
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
Mighty,
You said you checked the earth and feed to the battery so assume they are ok.
The light coming on and off may mean a bad connection/broken wire on the small feed wire
There should be 12 volts with the ignition on at the small terminal at the alternator.
Threads: 5
Thanks Given: 3
19
A good auto electrician can bench test it if you want to prove the alternator is faulty.
