Yet Another Central Locking Problem
Hi folks,
Am needing some help with my Berlingo Multispace 2005 2.0L Hdi.
The central locking appears to work fine but after several minutes it unlocks its self again and the interior light goes on and off at will!
This is discharging the battery over a period of 24 hours.
I have checked the wires from the door locks to the bsi for continuity and they are fine.
Any help would be appreciated.
Is there no one on here able to help me on this please?
Surely someone must have some input?
Try bsi reset?
This will not be much help to you but the only time my interior lights used to flash on and off was a sign that a door was not securley closed.
Thanks guys,
Have tried the bsi reset, and have now changed the front door locks incase one of these was playing up!
But only with s/h ones!
Do you think that the bsi memory may have corrupt itself and that is causing my problem?
Try disconnecting battery.dont forget the 3 minute rule
(16-10-2016, 09:55 AM)Johny555 Wrote:  Try disconnecting battery.dont forget the 3 minute rule
For the OP, "Jumpy's" sake, plus for mine and any future readers, could you expand on this "3 minute rule" thing please.
Before you discoect battery,wait at least 3 mins .this is what I do,unlock car,wind window down,pop the bonnet, close the door,wait at least 3 mins for the bsi to go to sleep,disconnect battery,leave a few mins,reconnect battery,wait at least 1 min,put arm thew window,turn side lights on,then start the car,do not open the door,turn side lights off,turn engine of,take keys out,lock car,then unlock car get in and start the car,then should be OK,that's the 3 mine rule,
[-] The following 2 users say Thank You to Johny555 for this post:
  • ghost123uk, jumpy
(16-10-2016, 10:36 AM)Johny555 Wrote:  Before you disconnect battery,wait at least 3 mins. This is what I do, unlock car, wind window down, pop the bonnet, close the door, wait at least 3 mins for the bsi to go to sleep, disconnect battery, leave a few mins, reconnect battery, wait at least 1 min, put arm the window, turn side lights on, then start the car, do not open the door, turn side lights off, turn engine off, take keys out, lock car, then unlock car, get in and start the car, then should be OK, that's the 3 mine rule.
Thanks for that Smile
I take it that ^^^ procedure is what is known as a "BSI re-set", yes?
I have kept a cut and paste copy of it in my "Berlingo stuff" folder Smile
Have done this several times, I read somewhere that there is supposed to be a bong noise! Is this correct as mine makes no bong?
Yet another ABS fault
Last Post: leftfootleashed
Today 09:09 AM
Today 06:29 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
