[Engine] Cambelt help URGENT PLEASE!!
I have a 1.9D lingo and am changing the cambelt, i have a couple of probs
1, the crank sprocket has a shitload of play on the keyway, like a tooths worth! is this normal??
2, yeah i know i should have pinned the damn thing up, but i tippexed, and forgot to tippex the injector pump, is this just a pump and dont matter, or have i buggered up in huge fashion?
3, IF the cambelt was a tooth out, what would happen?
i changed water pump, i took the glow plugs out to make it easier to turn engine over with a socket, also fixing an oil leak on cam cover.
i need help by morning please if possible.
thanks in advance.....
French Electrics......Grrrrrrr! Dodgy
If its a 1.9 you need to lock everything up - the pump will move if not locked up when you untension the belt. The 2.0hdis have an elongated keyway in the bottom pulley but not the 1.9 so i cant understand that one?
I would start by locking the engine correctly or you may cause yourself some damage!
(14-10-2016, 08:04 PM)polar Wrote:  If its a 1.9 you need to lock everything up - the pump will move if not locked up when you untension the belt.  The 2.0hdis have an elongated keyway in the bottom pulley but not the 1.9 so i cant understand that one?
i have turned the engine over by hand 20 or thirty times, nothing hits..the main question was, really i suppose, does the pump have to be timed up, as if it does i know ive lost the marks for it.....i had no guide or way of knowing what to pin or where, so im kinda working blind..
This will help you.
http://www.berlingoforum.co.uk/thread-3245.html
(14-10-2016, 08:26 PM)jj9 Wrote:  This will help you.
Thanks, but doesnt answer the pump question.....
I though it did....
Yes the pump needs to be timed up, the diagram in the link shows where the pump is pinned.
I can't answer why the crankshaft pulley has movement on the keyway.
  • Sootyfoot
oh right......thank you.... gotit now.......
looks like im taking the t**t apart again toimorrow.....lol
This may help you with the pulley question although its for a 2.0 ltr.
Berlingo HDI wont start after replacing pulley
[/url][url=http://www.berlingoforum.co.uk/thread-14315.html]http://www.berlingoforum.co.uk/thread-14315.html
(14-10-2016, 09:29 PM)Sootyfoot Wrote:  oh right......thank you.... gotit now.......
Unfortunately yes, you'll have to time the engine up with the pins to get the pump in the correct place.
hope i can figure out something to use as pins.....i could scream im so annoyed at myself
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
