Threads: 80
Thanks Given: 25
MINE ARE FACTORY FITTED AT 10" AND 27" OUT FROM CENTER, EACH WAY, LEFT AND RIGHT. hOPE THAT HELPS.
pETE
2010 artic silver VTR with EXTRAS.......
unny:
The following 1 user says Thank You to pch for this post:1 user says Thank You to pch for this post
• taxi
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
thanks , that helps as now there won't be any nasty surprises waiting for me and can drill in confidence-just need to buy the sensors now!!! Can you tell me the height also,thanks.
Former 2011 Mk3 XTR owner
alut:
Threads: 80
Thanks Given: 25
too dark to see now, will check tomoro, assuming I get it back from garage....going in for noisy front suspension and door rattle again under warranty.
unny:
Threads: 2
Thanks Received: 7 in 6 posts
12-10-2011, 09:45 PM
(This post was last modified: 12-10-2011, 09:51 PM by digger.)
Hi ya, Just got my XTR EGS6 Airdream about 3 weeks ago decided to fit Reversing sensores as I had Fitted them on My old Xara Picasso,s, If you look underneath behind the rear Bumper on the Berlingo (you will need a good tourch) you can see the Cut out Circle for the Sensors in the Middle of the bumper you will see 2 Long Slots, Look carefully into the slots and you will see the Outline of the hole to be cut for the two middle sensors, Look Oposite the rear wheels again the inside of the bumper you will see the Other 2 outline of the other Sensors where the Are fillted, Just use a sharp pointer and work from the inside of the bumper located the middle of all the Circilar Sensor markings and try to mark the center pushing on your sharp pointer hard enough so you can see the Point to drill on the rear Bumper, take off the R/H rear lamp to get access to the reversing lamps, the cables from the sensors comes from all sensors on the inside of your bumber through the hole that the rear light connector is, if you take the Boot Light/ tourch holder out, you can get access to the cables that way, I mounted my Reversing sensor unit behind there using dual sided tape as it cannot be screwed.
Digger
Threads: 80
Thanks Given: 25
where you have the indentation shape on rear bumper , from top of that indentation it is 2" up to center of hole needed to be cut. Sorry for delay, only picked up my car from dealer yesterday after warranty work[ see suspension thread / rattles]. You have other measurements, just in case you cant see from behind.
Pete
unny:
• taxi
Threads: 2
You have have to look hard with a light as the Hole profile is Etched on the Inside of the rear bumper, look for the 2 long slots first in the middle of the bumper they do stand out a bit..
will measure mine and post back on here..
The following 1 user says Thank You to digger for this post:1 user says Thank You to digger for this post
• taxi
