Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
hi folks the screen wash on my 04 has stopped working i can hear the motor going but no water. im supecting the pump could be blocked. ive a mot due in a couple of weeks so i have to sort it. can you tell me how to get at the pump is it behind the bumper. (hope i dont have to remove it ) thanks.
Threads: 28
Thanks Given: 78
Have you tried taking the tube that goes to the washer jets off and blowing back towards the motor ? This may clear a blockage.
Mark
Threads: 9
Thanks Given: 316
15
remove wheel arch liner make sure pump is pumping through pipe if pumping suspect blocked jets, if not replace pump. They freeze you try and use them and snap off impeller.
Threads: 43
Thanks Given: 3
18-10-2016, 07:48 PM
(This post was last modified: 18-10-2016, 07:49 PM by landcrab.)
Satellitemark yes i tryed that but no go.
polar yes i took off the jets and blew through no blockage in them i tryed the pump with the jet off just the pipe but nownt. so ive just ordered a new pump online . but was wondering how to get to it.
thanks for your replies.
Threads: 28
Thanks Given: 78
18-10-2016, 08:27 PM
(This post was last modified: 18-10-2016, 08:30 PM by Satellitemark.)
Polar says it's behind the wheel arch liner, I did the same job on my b9 with a replacement obtained on eBay , it took about 30 mins to do, it will make life easier if you jet wash the arch line before starting work, also stand back as you remove the pump from the tank as the water will flood out !
If it's similar to my b9 the procedure is
Remove wheel
Remove clips and arch liner
Unclip pump electrics
Pull pump from tank
Swap pipes from old pump to the new one.
Reassembly is the reverse of above .
Mark
Sent from my Vodafone Smart ultra 6 using Tapatalk
Threads: 43
Thanks Given: 3
thanks for that ill fit it when arrives. ill put up how i got on with it.
Threads: 43
Thanks Given: 3
as stated it took around 30 min to do.i brought a new pump of ebay £6.66 only differance was the pipes fit the other way around white to black and black to white. thats it then all ready for the mot in couple of weeks.
thanks for your advice lads.
