1.9 dw8 to b 1.8 xud engine swap
Hi, I bought a real clean 2003 1.9 berlingo but it had a stuffed  engine. I have a rotten mk1 berlingo but it has a real good engine so the plan was to swap the dw8 with the xud. All went to plan until I realised that the xud has a pull clutch arm and the dw8 has a push. No worries swap the boxes so now the xud has a dw8 box. Thought it would be simpler than changing cables ect. Now went to get a timing belt kit for the xud when realised its actually a 1.8xud and not a 1.9. No problems Im thinking its the same block so everything is bound to line up. Nah it dont, the bottom mount/driveshaft mount doesn't fit on the xud block and the xud one sits too high for the driveshaft to enter the diff. Does anyone know how to fix this? Any other mount for the pug/cit range fit?  Thanks in advance.
MOT Emissions repeated fail
22-01-2026 05:05 PM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
