Black Smoke
My 2010 B9 has done 35,000 miles and seems to smoke whenever the accelerator is pushed hard. I realise 'they all do that sir' but my car seems excessive. Any heavy use of throttle leaves black smoke in varying degrees behind.
The engine seems to run fine with no excessive noise.
I am now using Millers and almost used one bottle.
Is there somewhere I should be looking to try and trace the problem? Could EGR be the issue?
2010 Berlingo Multispace 1.6HDi - Chipped
Petrol or diesel?
Yes ive come across a low milage vehicle before where the EGR was causing black smoke - that was on a C4 though but still the same concept.
diagnostic sounds like a good move
Start with the air filter who does the servicing if it's Citroen they don't always change the air filter when was the last time the berlingo had a good run .
The car is a diesel.
The car is driven at around 70mph for two trips of around 15 miles every week plus other shorter journeys. It does not work too hard!!
The air filter was changed around this time last year and so I will change it and give that a try. Failing that are we saying check EGR?
[-] The following 1 user says Thank You to old son for this post:
  • Juno Benson
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
