New Battery
Nearly nine years on the original battery and winter is looming so, I'm thinking of a replacement to be on the safe side as I don't want to have a dead car during the first snowy morning.
Would you say it is best to use a fully charged new battery and :
A. Just change the thing.
B. Disconnect and leave the car for an hour to re-set the system before fitting the new one.
C. Use a voltage saver plugged in the cigar lighter so that the car doesn't know it's been changed.
D. Any other bright ideas.
I did "A" and nothing bad happened! In fact I've always done "A" on every car I've had.
Follow BSI shutdown procedure
Get another battery some jump lead's use the earth lug on the body next to the battery for the neg connect the pos to the live cable the one with the fuse's on just right of the positive terminal take off +/ - on the old battery lift out old battery fit new one .
Oh I see, you're supposed to wait 3 mins for the BSI to go to "sleep". Took me longer than that to work out how to actually get at the battery, so I guess I got away with it. Pretty dumb if the system is that unresilient to just have the power pulled on it!
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
