  • 7 Vote(s) - 3 Average
Fuse Box Problems - BSIE
Hi,
I seem to be having what looks lke a common problem. First the dash lights started playing up, and then the wipers, and now the car will not start.
After looking around on the net, it looks like it will be the fault of the fuse box under the steering wheel.
I've taken it out, and got the following numbers off of it;
BSIE01-00HC
S118085320E
Is there any issue with getting a different one, and then just replacing it - are there any programming issues I need to watch out for?
I managed to track a second hand one down, that has the following number:
S118085320A
The difference only being the last number - any idea if this will work?
Finally, if it does not, does anyone know where I could find a second hand unit?
Thanks alot
Chris
Hi Chris and thanks for saying hello. Might help to know what type of Berli we're talking about here. Then the guru's can chime in.
It may be that all that's needed is for the BSI to be reset/or the firmware re-written.
Authorised Citroen repairers can do this and they're cheaper than main dealers.
Although you'll have to find a garage that have Citroen's Lexia
or the Peugeot equivalent it may still prove to be the cheap option.
I very much suspect that if you were to get a s/h BSI unit it would still need to be set up for your vehicle.
HTH:thumbsup:
Hi,
Thanks for the reponses so far.
it's a 2007 1,4 petrol van
cheers
chris
Hi Chris.
Who is manufacturer of BSI? Siemens, Valeo?
Siemens
Have you tried the BSI reset procedure? It can be found here:
http://www.bba-reman.com/content.aspx?co...ol_failure
Worth a shot??
Does any aftermarket alarm system installed in your car?
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
