Removing Fuel tank/ sender unit faulty ??
Anyone here ever had a problem with the sender unit located in the fuel tank ?
I think it may be whats causing the fault with my van,
Its alternating between surging and loosing power but only happens when the tank is a quarter or less empty.
When i fill her up the problem vanishes.
Anyone removed the fuel tank before, hard/easy job ?
In your other thread you mentioned a hiss when you opened the fuel filler cap, before thinking of removing the tank I would try to fit a small bit of wire or similar accros the seal in the fuel filler cap so you know it is venting correctly.
[-] The following 1 user says Thank You to Trevor for this post:
  • michaelg
Thanks Trevor, good idea, ill try that,
You sure the fuel cap is supposed to vent ?
Berlingo undertray
Today 08:56 PM
» Replies: 23
Air filter box removal
Today 06:50 PM
Yesterday 10:10 PM
» Replies: 21
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
