[Tires & Wheels] splayed rear wheels
Threads: 2
Thanks Given: 2
we don't actually own a berlingo yet but test drove 1 yesterday, it did all the things asked of it, started straight away, braked straight, gears, clutch all sound, however it does have slightly splayed rear wheels, its a 53 plate, not expensive & has 9 months MOT, [we haven't seen the test cert yet, so don't know the advisories, might run a mile if they are bad] if its the wheel bearings would it be worth a punt & anything else we should look out for, husband is quite useful with mechanical stuff, we also have a Maxus, so he has to be. Cheers
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
It would be Easyer replacing the rear axle,than mess about trying to strip it down,I bought a recon one £300. Plus £120 to get it fitted,if it needs an axle budget £500 for that,I was going to do mine myself until I read some horror story's on here about the bolts being seized, and the nuts in chassis just spinging round and have to cut holes in the floor to get to them,so I just booked it in my local garage and let them do it,
Threads: 2
Thanks Given: 2
(27-10-2016, 10:39 AM)Johny555 Wrote: It would be Easyer replacing the rear axle,than mess about trying to strip it down,I bought a recon one £300. Plus £120 to get it fitted,if it needs an axle budget £500 for that,I was going to do mine myself until I read some horror story's on here about the bolts being seized, and the nuts in chassis just spinging round and have to cut holes in the floor to get to them,so I just booked it in my local garage and let them do it,
thanks for that, think that would be more than the van is worth, def making us think that this particular vehicle might best be avoided
Threads: 4
Thanks Received: 10 in 10 posts
Thanks Given: 2
I agree. I got mine cheap because of the wheels being like this /-\ £300 for a reconditioned axle delivered from IM Axles on e-bay and a couple of afternoons cursing and getting grit in my eyes doing the job, needs two pair of hands really to get it lined up and put on. Would I go it again? NO!!!
Sent from my SM-G361F using Tapatalk
2006 Berlingo 2.0hdi desire daily hack
1998 Xantia Activa turbo for fun.
Threads: 8
Thanks Received: 498 in 447 posts
Thanks Given: 301
31
You'll have to look very hard to find a mk1 or 2 Berlingo that doesn't have some splaying.
Unless the car has recently had a reconditioned axle fitted it will have bearing ware, they all do as the bearings are crap and not really up to the job.
Just because the wheels are splayed a little doesn't say that it won't go on for years but obviously do a few checks like rocking the suspension from side to side, and up & down listening for bangs and clunks.
If the car is cheap enough and in good condition just get it and run it, worry about the problem when it is a problem.
If hubby is handy a rear axle change (if needed) isn't the end of the world and then you know it's ok!
Threads: 4
Thanks Given: 2
I only changed mine because it had advisories for both sides on its mot, and was cheap enough to buy to allow changing it. That's a couple of months I have had mine now and it's a brilliant motor!
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
Hello and welcome to the forum good to have you with us .
If go on your pc tap in .gov mot look to the top right of the screen you will see mot check click on that put in the reg you can see the mot's pass / fail and advisory's .
Threads: 8
Thanks Given: 301
31
27-10-2016, 10:36 PM
(This post was last modified: 27-10-2016, 10:37 PM by jj9.)
Yeah, if the axle is bad the MOT tester will pick it up, most testers know the score and unless it's really bad will let slight splaying go.
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
