Threads: 22
Thanks Received: 21 in 18 posts
Thanks Given: 31
Anyone know where to *buy a replacement plastic Key Fob body for an 08 MK3?
*At a reasonable price*
Key and Circuit Board both okay but the bit of the plastic that holds the swivel bit of the key in the casing has broken off!
woodshaper
Sole Member and President for LIFE!
Threads: 21
Thanks Received: 19 in 17 posts
Thanks Given: 6
I know they do them on E-Bay, apart from that haven't seen them any where else.
Doc..
The following 1 user says Thank You to Drew for this post:1 user says Thank You to Drew for this post
• woodshaper
Threads: 52
Thanks Given: 87
5
Just had a gander on ebay.de and they have a lot of them. All in the € 9-10 range.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• woodshaper
Threads: 22
Thanks Given: 31
12-10-2011, 04:53 PM
(This post was last modified: 12-10-2011, 05:10 PM by woodshaper.)
Have found a metal/alloy case on flea bay that is for a Berlingo van, it seems to be identical apart from 'lock' symbol so have taken a chance and ordered one! (at a fraction of Citroen price)
NB: Dealer has stated that case is NOT covered under warranty, only key and Circuit board are but only for first two years!!!!!!!!!!!!:S
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
12-10-2011, 05:08 PM
(This post was last modified: 14-10-2011, 10:20 AM by Ol'Jeffers.)
Apologies for the off-topicness, I should know better...:oops:
Threads: 22
Thanks Given: 31
13-10-2011, 09:39 PM
(This post was last modified: 13-10-2011, 09:44 PM by woodshaper.)
Update on my search for a replacement Key fob, got one from TopFobs shop on ebay for just under ₤12.00 and delivered next day. (with 2 batteries included)
Almost an exact match for the original case apart from the 'lock' symbol is smaller on the new one BUT, the new one is made of a metal/alloy not plastic so should be more hard wearing.
Fitted my existing Key and Circuit Board into it with no problems!
woodshaper
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
Its unreasonable to expect warranty on discs as they are a wearing part and wear in accordance with mileage covered and driving style. Due to the non asbestos brake pads/linings used now the discs take a lot more hammering than the old days.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 22
Thanks Given: 31
(13-10-2011, 09:52 PM)divingscubaboy Wrote: Its unreasonable to expect warranty on discs as they are a wearing part and wear in accordance with mileage covered and driving style. Due to the non asbestos brake pads/linings used now the discs take a lot more hammering than the old days.
woodshaper
Threads: 13
Thanks Given: 7
14-10-2011, 08:19 AM
(This post was last modified: 14-10-2011, 08:19 AM by divingscubaboy.)
@ wooodshaper - see post above from ol jeffers. Granted its a deviation from the original thread.
alut:
