Gears / Clutch problems
Hi
I have a 2007 Diesel Multispace.   For a little while not the clutch has been slipping, but only slightly, and only every now and then.  We asked our local garage if the clutch needed to be replaced and they suggested leaving it for a while as it was not causing much of a problem.
Today, the gears seem to have moved position... Reverse is now straight down, where 4th would usually be.  Second and fourth are now off to the left.  5th is straight up, and 1st and 3rd are off to the left.   So it's like everything has moved to the left.
It can be driven, and all gears can be selected, although it's a little sticky.
So, what I want to know is what could the problem be here?  Am I looking at a new gearbox and clutch?
Anyone know roughly how much the gearbox costs to be replaced?
Thanks in advance.
Could be the gear linkage
my gearstick is very sloppy (worn linkage) but all my gears are where they should be !! your problem ???? sorry cant help you
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
(30-10-2016, 07:28 PM)Johny555 Wrote:  Could be the gear linkage
I'd go along with that.
before you start spending big bucks on the new gearbox !!! get under the car and take a look at the gear linkage first
Yeah, the car is at the garage now. Fortunately I know the mechanic, and I'm confident he will sort it. First thing he said was linkage or cables were probably the cause.
Let us know the out come,
Yesterday 05:06 PM
Yesterday 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
