Threads: 10
Thanks Received: 11 in 5 posts
I fitted a new clutch kit and after around 30 miles with no problems I have now noticed a squealing/grinding noise in reverse only.
It sounds like metal on metal I have been told its my release bearing but since it is new and seemed to have no defects when I checked before fitting I don't think it is. It happens when moving off in reverse only when slowly engaging the clutch.
Thanks in advance for any advice
If in doubt smash it to bits :woop:
:thumbsup: 2006 1.9D Multispace Forte
Threads: 5
Thanks Received: 10 in 10 posts
Thanks Given: 2
Sounds very much like thrust bearing, did you change the plastic guide tube when fitting the new clutch.
2012 Berlingo Multispace VTR 1.6HDI White
Threads: 8
Thanks Given: 305
36
If it was the thrust bearing surely it would be making the noise when engaging all gears and not only reverse?
Is the reverse gear engaging fully, check the gear linkage.
Threads: 29
Thanks Given: 67
20
(30-10-2016, 11:56 PM)jj9 Wrote: If it was the thrust bearing surely it would be making the noise when engaging all gears and not only reverse?
It's just a whining reverse gear, most cars do it. As above the thrust bearing is doing exactly the same in reverse as forward so no reason to blame that. Do yo spend a lot of time going backwards ? Put some oil in the box for peace of mind and live with it.
Threads: 20
Thanks Given: 2,126
18
Did you lube the input shaft bearing/bush in end of crank? Just wondering if you spend longer on the bite point in rev?
Strawberry flavoured windows
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
I would be looking to see if you have left something (mounting) off or loose when refitting gearbox. The engines torque reaction moves in the opposite direction when in reverse so a driveshaft or pulley could be touching something.
