Threads: 2
Hi guys, here's the problem...
Engine warning light is on but my odbii code reader says there are no faults. Is it a crappy code reader or a dodgy dash light?
Any clues?
Sent from my VF-1397 using Tapatalk
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
02-11-2016, 12:40 PM
(This post was last modified: 02-11-2016, 12:41 PM by Col.)
Beg to differ brajomobil. A good PRO reader will have no problem (Snapon / Launch / Mac etc) Mine even reads airbag, security and ABS faults gives live data etc:
I use mine all the time as it's a pain to fire up my laptop to use Lexia / PP2000. I Only use Lexia for certain PSA specific stuff like Peugeot cabriolet roof issues. I suspect the OP has a cheapy ebay special which aren't too clever.
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• brajomobil
Threads: 20
Thanks Received: 23 in 20 posts
i have a few scanners.
all work to an extent for a quick fix BUT if im ever in doubt about what the cheepies are telling me OR they tell me no fault or cant give me a code.
I break out the lexia and it tells me everything.
Its even surpassed the garage' snapon unit at times (the MAF sensor being dead didnt give a code on the snap on - it does on lexia)
