  • 24 Vote(s) - 2.42 Average
Lexia 3 Air bag light Help.
[/font]Hi to all.
I recenctly purchased an 06 Berlingo 2.0Hdi van with the air bag light lit on the dash. So did the usual seat connections and steering one which all seemed ok. It still remained lit.
So I invested in a lexia 3 unit of ebay to see if that would point me in the right direction. The software installed and updates were succesful. Can any one tell me why this doesn't seem to be connecting to the ecu to read the codes? It goes through the scan but doesn't pick up any faults. Does the unit have to be configured or am I just not doing it right? Has anyone managed to get these units working on an 06 plate vans?
Cheers.
I'm still fumbling with mine on a MK3. I was cautioned by a very knowledgeable member of this forum not to mess with airbag settings unless you really know what you're doing. Can lead to surprises.
(12-10-2011, 02:38 PM)Rustscrat Wrote:  [/font]Hi to all.
Cheers.
Lexia works on all PSA cars. If it's not work this can be:
1. Updates with bugs.
2. Inside plastic box is not Lexia.
Go to "Airbag" menu and read errors. Only read and that's all!!!
Otherwise, you'll know how airbag works SmileBig Grin
Thanks for the warnings - The problem for the minute though is that I can't get the unit to comm with the ecu. Have tried with the "scantool" but this again comes up with "No dialogue with ECU during initialisation"
Any idea's?
See item 1 in a previous post
Yeah, with scantool I get the same error. With the Lexia choice it tells me that the ECU is unrecognized and that the value may not be valid. Right now reviving my schleptop.
(12-10-2011, 05:44 PM)Rustscrat Wrote:  Thanks for the warnings - The problem for the minuite though is that I can't get the unit to comm with the ecu. Have tried with the "scantool" but this again comes up with "No dialogue with ECU during initialisation"
Any idea's?
From the same experiance as you when setting up Lexia do the following:
1, Check all your fuse`s in both BSI and BSM- Replace any failed fuse`s .
2, Do a BSI reset then have another go with Lexia.
2003 Citroën Berlingo 2.0HDi Multispace Desire
Thanks for *ALL* advice fella's - Will try tomorrow and let you know what happens.
Checked all fuses and connections in bsi & bsm modules - all ok. Still getting "No dialogue with ECU during initialisation". Starting to wonder if the bsi unit is U/S. Might strip it out and check as it looks like thers's liquid spillage from the top of the dash.
Anybody know what would not work if this is the case ???
Thanks.
(13-10-2011, 05:58 PM)Rustscrat Wrote:  Checked all fuses and connections in bsi & bsm modules - all ok. Still getting "No dialogue with ECU during initialisation". Starting to wonder if the bsi unit is U/S. Might strip it out and check as it looks like thers's liquid spillage from the top of the dash.
Thanks.
Did you read my pm regards Lexia updates ?
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
