Threads: 3
Thanks Given: 6
Hi all, my bingo ms has decided it doesn't want to start so easily when cold!! I'm quite handy with tools so just wanted to know a starting point before I throw money at the wrong parts!! it's a 04 1.9d with 77k and regularly serviced - it's been running and starting fine for months but I recently left it for a week and went to start it and it took a good few seconds and turns to get going followed by a cloud of grey/black smoke (reminded me of my dads old black cabs lol) the smoke cleared, it ran fine and I thought nothing of it as it started fine when warm. The problem is, it's getting worse - taking longer to start!! Once started it runs perfect!!!
Any advice would be appreciated - ta
Threads: 20
Thanks Given: 2,126
18
Glow plugs or relay?The mileage is a bit low to suspect tight valve clearances.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• Mishmat
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
Best try one thing at a time to pin point the cause, don't go changing two things at the same time as you won't know what the cause was!
Check the glow plugs & relay first.
• Mishmat
Threads: 8
Thanks Given: 305
35
22-11-2016, 07:21 PM
Good to hear you've sorted it out
Threads: 20
Thanks Received: 23 in 20 posts
Had same issue here
3 plugs were damp. And would heat up but not glow with 12v . O ly 1 was dey and glowing right.
Picked up glow plugs today fitted em and it starts with hardly a turn over now.
