2.0HDi ECU types and replacement
Thanks Received: 3 in 3 posts
Thanks Given: 8
I'm going to need to fit a new bsi into my van (2003 2.0hdi). So it seems I'll need to buy the set of bsi, ecu, key and transponder.
There seems to be at least 2 types of ecu (Bosch and Siemens). Guessing they aren't compatible, but wondering if I need to find the same as I have already (Siemens), or if I bought the bsi/key/etc to match, could I fit the Bosch unit?
Anyone know, or know a better way?
Ideally I just need a new bsi, but don't want to be going to a dealer to get it coded
Fire bad, tree pretty
Threads: 19
Thanks Received: 19 in 19 posts
Thanks Given: 33
05-11-2016, 09:27 PM
(This post was last modified: 05-11-2016, 09:28 PM by Civvic.)
(04-11-2016, 11:17 AM)Kez Wrote: I'm going to need to fit a new bsi into my van (2003 2.0hdi). So it seems I'll need to buy the set of bsi, ecu, key and transponder.
http://www.peugeotlogic.com/workshop/wsh...code1d.htm
check if that link can be of any help.
Threads: 19
Thanks Given: 33
(05-11-2016, 09:27 PM)Civvic Wrote: (04-11-2016, 11:17 AM)Kez Wrote: I'm going to need to fit a new bsi into my van (2003 2.0hdi). So it seems I'll need to buy the set of bsi, ecu, key and transponder.
Also this
http://www.peugeotlogic.com/workshop/wsh...incode.htm
Thanks Given: 8
I'm confused.. why have you given me links to peugeot models and engine numbers? This is a Citroen, and I already know the ecu is the correct type
Threads: 19
Thanks Given: 33
05-11-2016, 10:42 PM
(This post was last modified: 05-11-2016, 10:43 PM by Civvic.)
(05-11-2016, 09:58 PM)Kez Wrote: I'm confused.. why have you given me links to peugeot models and engine numbers? This is a Citroen, and I already know the ecu is the correct type
RHY engine - same in both models. check the last column for details on ecu/ fuel system
Threads: 19
Thanks Given: 33
(05-11-2016, 10:42 PM)Civvic Wrote: (05-11-2016, 09:58 PM)Kez Wrote: I'm confused.. why have you given me links to peugeot models and engine numbers? This is a Citroen, and I already know the ecu is the correct type
Sorry I have realised that my response wasn't appropriate to the question. However, I can't be of much help with that as it needs someone who has done a similar swap. My belief - and I stand to be corrected is that the fuel system and the ECU kit (bsi, ECU, keys) are made to match and a swap would have to include some components of the fuel system as well.
Thanks Given: 8
Well so far I've swapped the ecu, bsi, clocks, transponder and the receiver bit that goes around the key. The new ecu is exactly the same as the original (same number), but the van won't start. Seems like its immobilised, there's no glow heater light and the fuel system doesn't seem to be operating
Threads: 19
Thanks Given: 33
(06-11-2016, 04:35 PM)Kez Wrote: Well so far I've swapped the ecu, bsi, clocks, transponder and the receiver bit that goes around the key. The new ecu is exactly the same as the original (same number), but the van won't start. Seems like its immobilised, there's no glow heater light and the fuel system doesn't seem to be operating
Try to check fuel rail pressure while you're cranking. It may be worth ruling out Low fuel rail pressure issues.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
08-11-2016, 09:04 PM
(This post was last modified: 08-11-2016, 09:04 PM by dumdum.)
Use planet to see if the transponders are being recognised, if correct check cam/crank synchronisation and fuel pressures (desired vs actual) as this will stop the engine starting, but I dare say it'll be something basic you've over looked, also check the bsi and engine are matched
The aerial on the barrel shouldn't need changing, and key being recognised would rule it out...
2.0 hdi don't have a fuel pump in the tank if it has a primer bulb in the engine bay
You need someone experienced with planet/lexia to have a look
Thanks Given: 8
Random Q .. is Planet/Lexia capable of virginising/programming a bsi?
Yesterday 10:10 PM
» Replies: 21
Berlingo undertray
Yesterday 09:59 PM
» Replies: 19
Air filter box removal
Yesterday 06:18 PM
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
