Anyone on here got an Electrique / E500?
Flushed with success getting the old multispace on the road for less than £200, attention is now drawn to the Electrique that is in dry Storage awaiting diagnosis. Converted to 5 seat car. Batteries all good, it felt and sounded like a mechanical issue, collapsed bearing maybe?
Might be able to help with a little more info.
Are you getting a strange noise or what ,
Does it move at all ?
Big Grin
(04-11-2016, 03:04 PM)brodfather11 Wrote:  Might be able to help with a little more info.
Ok, masquerading as the wife again........from memory. The daughter was driving it and "it just stopped". Further interrogation revealed that she stopped at a Tee junction and then car wouldn't budge without the Eco meter going into the forbidden red zone.
further investigation confirmed that, in forward and reverse, the car would creep forward but only with foot full down, so tried it with both wheels off the ground. Strange noise from off side/ wheel/driveshaft? which translated as a dozen(ish) cluncks per revolution of the wheel.
Other emergencies and projects then took over.....
On a not so dull day i will get into the dark and dingy barn to have a memory refresher
ServiceBox
Last Post: nonce
Today 03:28 PM
Limp mode, no other symptoms.
Today 11:37 AM
Adding aircon oil after component replacement
Today 11:23 AM
Centre Air Vent On Dash
Yesterday 10:50 AM
05-07-2025 11:41 AM
» Replies: 36
2.0 hdi clutch
05-07-2025 06:20 AM
Solenoide, Wastegate
05-07-2025 02:27 AM
All NS front head lamp bulbs blown?
05-07-2025 02:15 AM
Power steering Leak
Last Post: AugustinoHippo
01-07-2025 11:09 AM
install other safetywall
Last Post: mikeh79
01-07-2025 09:48 AM
