[Engine] hdi engine confused
hi all
my engine has let go in my 2009 berlingo 1.6hdi ,,so i am trying to source a engine but getting a bit confused as to what engine i have in there,cannot find the engine code on the block, there is a white label down the pulley end which says DV6ATED4   and on the citroen service site it says mine is  DV6BTED4    and my vin is VF7GB9HWC   so i think im looking for a 9HW engine but im not so sure hopefully someone here knows as there is so many engines with different codes and dont want to get the wrong engine
thanks all
(05-11-2016, 03:51 PM)tommy1 Wrote:  hi all
thanks all
You can send me complete VIN number by PM and I can check
your engine number that was factory fitted.
Maybe there was already differend engine in you car  Rolleyes
Best regards,
brajomobil
For your vin number:
Best regards,
brajomobil
thanks
got the new engine and just got the old engine/box out
engine has a big crack just above the sump about 3 inches long also
all the flywheel bolts were sheered off so flywheel clutch just all laying
inside bellhousing
any ideas what could of happened as it had plenty of engine oil
and never got hot and happened on motorway doing 70mph and
just lost power and then wouldnt start,had strange noise from engine when
pulled to hard shoulder
2009 1.6hdi 112000 miles on clock
ideas anyone
Sounds like bottom end locked up
Oil sump clogged. Oil not getting to top of the engine.
Oil pump not working.
I had similar case long time ago on vw 1.6 D.
You can take valve cover off and see if there is NO oil there.
Best regards,
brajomobil
Just a thought, did it have an oil filter change recently? Maybe the filter was inserted incorrectly.
Or maybe oil and filter not changed in a long time, I'm not trying to be controversial, just trying to understand the failure to help others.
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
