How Often Coolant changed ?
Excuse the ignorant question Smile
How often should the coolant be changed ?
I've no idea when my 02 was last done, had a small leak a few years back and a bottle of Novastop sorted it.
While we're on the subject of fluids , how often gearbox oil ?
If you work on coolant 5 years and gearbox oil every 50k you wont go far wrong - the specs do change between manufacturers and oil companies so its a bit of a grey area.
Citroen give no guidelines for either of your above questions which is not unusual.
Blue antifreeze is two yrs, red or green antifreeze is 5 yrs, and gear oil is generally changed when the clutch is, harder you are on a gearbox the quicker the clutch wears out generally...
Rattling calipers
Last Post: Chrisfox1975
Yesterday 08:09 AM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
