Good day
Hope i can get some help. i have a 2007 Berlingo and have the dreaded airbag issue.
Put it on Delphi Diagnostic and came up with 4 faults,, 3 relating to left Squib And one
relating to Left front satellite- Present.
I have done all the under seat stuff. faults came and went. so took the plunge and hard soldered
all of the joints under the passenger seat.
Reset the codes and hey presto and life is good.
Took the car for a run, then stop start, stop start. Still all good.
However when i leave it for 10 minutes or so and ignition on, fault comes back.
only fault now showing Left front satellite- Present.
If i clear the fault code, light goes out and comes back as above again.
Any ideas ?
Is the Satellite a sensor ? if so where are they located.
Any information would be gratefully received
Any ideas ?
