  • 16 Vote(s) - 2.81 Average
Multispace uk drivers side, slide door lock
Recently when I have locked the car the passenger slide door on the drivers side doesn't always lock but the rest of the doors and boot all do (luckily I pull a handle before I walk away) anyone have any ideas what the problem could be?
Thank you
Lliam
Lliam
70 plate Berlingo
Off the top of my head I'd suspect an intermittent electrical connection to the lock, something partially blocking the mechanism or maybe corrosion preventing it from operating at times. Reasonable things to check out since it involves just one door.
Thank you, This has only happened twice and not since but I will try to look at the door when i have a day off
Lliam
70 plate Berlingo
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
