12-11-2016, 09:24 AM
(This post was last modified: 12-11-2016, 09:25 AM by ghost123uk.)
OK, so up until very recently, our Citroen Berlingos are only equipped with a pretty basic radio that does not have any Aux inputs or Blue-Tooth
I also understand, from what I have read, that it is no simple matter to upgrade the radio as doing so upsets the "BSI" thingy
(Not sure if it throws up an error code or what ??????)
Anyway, here is a tip for you if you wish to use your phone as a music source.
I use a Plantronics K100 blue-tooth thingy so I can take phone calls legally whilst on the move. It clips onto the sun visor.
You can see (and buy) them here https://www.amazon.co.uk/Plantronics-K10...onics+k100
The cute thing about this device is it has a reasonable quality FM transmitter built in. You simply tune your standard car radio into the frequency you have chosen on your Plantronics K100 (I use 88.7 mHz as that is unused in my area) and then you can stream music from your phone to the car radio.
By the way, the (rechargeable) battery life on that K100 is AMAZING. I only have to charge it up about once every two MONTHS and I use it almost daily.
If you need any more info, just call out
(Not sure if it throws up an error code or what ??????)Anyway, here is a tip for you if you wish to use your phone as a music source.
