Threads: 8
Thanks Received: 2 in 2 posts
I dont know if modern vehicles use the speedo drive from the wheels nowdays, i think there measured from the gearbox or electronically so dont think it would matter what wheel size ya running, i could be wrong am not that clued up on berlingos but have been a mechanic in the past and thought most cars are run this way now?
Threads: 32
Thanks Given: 24
Yes, the speedo is electronic, not the old cable type. However, this would read the number of revolutions of the gearbox which would not equate with roadwheel revolutions if a different wheel/tyre size is used.
15" wheels were fitted as standard so the speedo etc would have been accurate +/- 10% as it left the factory.
If reducing the rolling circumference of your tyres your speedo will over read i.e. will indicate that you are travelling faster than you actually are. This will only be a negligible amount but will ensure that if you stick to the indicated speed, you won't get done for speeding !!
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
My bingo has 14" wheels as standard. The sticker on the door pillar and the handbook both state this. I wouldn't say 15" rims were standard!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 32
Thanks Given: 18
Stick with the 15's, mine had 14's (175/65/14) on as standard but the ride is far smoother and handling better with 185/65/15, the speedo is a tad out, when I'm doing 70 by the speedo, sat nav says 73 so I just keep it a smidge under, no problem.
Threads: 32
Thanks Given: 13
The forte came with 14 inch wheels, the desire came with 15 inch.
So it depends which model you have to determine which wheel size was standard for the car.
Threads: 32
Thanks Given: 13
I don't understand what you are referring to there. The Berlingo brochure which I have from 2003 and used when I bought mine shows the forte model had 14 inch wheels and 175 tyres and the desire came with 15 inch and 185 tyres.
15 inch is the standard on the desire?
Threads: 13
Thanks Given: 7
Ive always thought it a bit odd why car manufacturers do fit different size wheels and tyres. Considering its one of the most important safety aspects, wider rubber and lower profile ratio's will in most circumstances equal greater grip and better handling but poorer ride quality. You would think that the manufacturer would settle on a happy medium and that would be that. I understand that high performance cars in a manufacturers range require additional grip etc but otherwise its just bling. In the case of the bingo the forte and desire can be exactly the same vehicle in terms of performance but in theory one could be safer than the other, how does that work?
alut:
