Threads: 2
Hello everyone,
I was driving the van today I put the lpg on and the van stopped after 10 or 15 seconds it's as if it's not getting the gas. When I got back home I checked the coolent and it's fine after that am beat I need help
Steviez
Threads: 67
Thanks Given: 238
50
LPG solenoid working ?? voltage check first then crack a pipe and sniff the gas ... hmmm yum !
Serieal Berlingo owner
Threads: 32
Thanks Given: 13
I would suspect it would stop sooner as in straight away if it's not getting gas.
Did it run rough before it cut out? Could be an injector problem.
Threads: 2
Hi all,
And thanks for all the answers I got it sorted, went back to the gas man he said when they where putting in the towbar the valve wasn't turned on again.
