Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
hi all ,my gearstick is very sloppy, i am getting my gears ok, but i do miss one now and again,i have been told the rods need changing ,is this a big job,is it an easy job,and how do i change them???your help would be very much appreciated.i have searched the threads but nothing turned up, unless i worded the search wrong.
many thanks Gwyn
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 29
Thanks Given: 67
20
16-11-2016, 09:41 AM
(This post was last modified: 16-11-2016, 09:46 AM by ffrenchie.)
I did the long one on my niece's Pug Partner. I jacked the car up and knocked the link upwards with a piece of wood and a hammer, not a long job and just a bit awkward. She had just driven 60 miles back from Birmingham with only 2nd, 3rd and 5th gears and wanted it straight away so we got a part from Citroen garage about £25 but you can get all 3 links on eBay for about the same. The new parts just push down and click on the ball joints nothing complicated. Put gear linkage in your search and you should find some help. If you put Berlingo gear linkage in google you will find video of the linkage.
Threads: 69
Thanks Given: 7
4
thank you ffrenchie you are a true gem cheers(so where does this bit go then) i'll be saying that now when i start the job,
