Aerial fault
Hi. As anyone removed the roof lining on a 2006 Berlingo Enterprise Van so as to access the roof mounted aerial, if so any advice would be  appreciated. cheers. Rob.
When you remove the shelf, there is a small cut out in the roof lining where the wires for the interior lights come down. You can access the antenna fixings from here.
Shelf removal = total of 4 screws - Two screws, one either side of sun visors, and two screws behind interior lights.
(17-11-2016, 12:01 PM)Jo3ey Wrote:  When you remove the shelf, there is a small cut out in the roof lining where the wires for the interior lights come down. You can access the antenna fixings from here.
Thanks for that, I managed to replace the Aerial but the radio still won't work, that is it will come on but will not tune into any stations.
Any ideas. ??
Sorry, only seeing post now. Was the power cut to the radio/new radio. Does it need to be 'matched' to the car  ?
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
