Ligts won't go off!
16-11-2016, 07:27 PM
(This post was last modified: 16-11-2016, 07:28 PM by Berlingos12.)
Guys I need help!
I have had my car at a friend that is mechanic, but he can't figure it out because everything seems as it should be.
The problem is, when ever I turn off the engine, and shut off the lights, the fog lights remind on, back and front.! Wires, fuses and relays seems ok. Also the contact in / on the switch.
Have any of you guys any idea whats going on?
Edit: Berlingo multispace 2002 mod.
I'm so tired of disconnecting / connecting the battery when ever I park / have to use the car.
Threads: 123
Thanks Given: 250
34
The fog lights are on, even when the headlights are off? I'm guessing that the logic controlling the fog lights is in the BSI, so if you search for 'BSI reset' and try that, it may help.
(16-11-2016, 08:58 PM)cancunia Wrote: The fog lights are on, even when the headlights are off? I'm guessing that the logic controlling the fog lights is in the BSI, so if you search for 'BSI reset' and try that, it may help.
Thank you! I will try that tomorrow!
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
17-11-2016, 07:14 AM
(This post was last modified: 17-11-2016, 07:16 AM by brodfather11.)
He said his fog lights back and front ?, his location is Europe and English may not be his first language so something being lost in translation and means sidelights?. If its them staying on, I wonder if the rear light cluster have a wrong bulb in them ?.  That plus a tow bar wiring mess !
Pure speculation of course
Threads: 123
Thanks Given: 250
34
(17-11-2016, 07:14 AM)brodfather11 Wrote: He said his fog lights back and front ?, his location is Europe and English may not be his first language so something being lost in translation and means sidelights?. If its them staying on, I wonder if the rear light cluster have a wrong bulb in them ?. That plus a tow bar wiring mess !
Also 'he' could be 'she', it's a good point though  .
All bulbs have been checked and are as they should be. Someone called them fog lights and it stucked. Anyways, its the headlights, just not the lights thats on when you drive. Parking ligths maybe.
Threads: 123
Thanks Given: 250
34
Uhu, parking or side lights as they used to be called when I was young. Spot on Brodfather! They are in the same place as the main lights.
Did you try the BSI reset?
(17-11-2016, 06:26 PM)cancunia Wrote: Uhu, parking or side lights as they used to be called when I was young. Spot on Brodfather! They are in the same place as the main lights.
Yes. Didn't work
Threads: 123
Thanks Given: 250
34
21-11-2016, 11:48 PM
(This post was last modified: 21-11-2016, 11:48 PM by cancunia.)
Could it be like brodfather thought, maybe some faulty towbar wiring?
(21-11-2016, 11:48 PM)cancunia Wrote: Could it be like brodfather thought, maybe some faulty towbar wiring?
Would made sense if I had a towbar.. Never had that..
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
