17-11-2016, 06:56 PM
I need some help to identify the wiring on a ISO connector for this particular Berlingo. I know there is couple of people on here who know what they are talking about and probably will guide me in the right direction. I'm going to end up fitting an aftermarket stereo and I want to prepare myself knowing which wire does what.
Here are the typical ISO connectors and the color coding for this particular Citroen:
http://i.imgur.com/imNzEqT.jpg
http://i.imgur.com/SuIrrEw.jpg
http://i.imgur.com/ImO2iKd.jpg
http://i.imgur.com/LhI3AiE.jpg
Here are some of the speaker wires that don't match what's on the ISO
http://i.imgur.com/B3z45aY.jpg
http://i.imgur.com/NmJ7WxT.jpg
http://i.imgur.com/3dUPMEY.jpg
http://i.imgur.com/kKPZ8jm.jpg
So i've done half the work to help you out identify what's going on here. We have 6 speakers total meaning 12 wires that don't make sense or color match the white ISO speaker connection. I assume they don't directly go to the connector and terminate somewhere (while change color), also I don't quiet understand the pairs either. the white connector is a 8 pin, all pins taken, with 4 pairs. I pressume the further away speakers use thick gauge wire, while tweeters and fronts are thin gauge due to distance. The black connector has 6 pins taken and 1 pair (thick yellow and thin yellow). I need 3 wires from here, I suspect the others are extras like the top display, or blue wire was for some remote stuff that this car hasn't got. Trouble is how do I differentiate them. Again suspecting the thicker gauge is where it matters, but which one is ignition...
