Thanks Received: 213 in 171 posts
Thanks Given: 44
5
Rear brakes have developed a squeak. Not when applied but when driving. It's noticeable at low speed. Apply brakes & squeak stops. It's been like this for several months & about 6k miles. Car, 09 reg is on 80k miles & rear pads have never been changed. Would this be caliper seizing up I wonder, or might I get away with just new pads at next service due in Feb? Pads are only about half worn. Front discs/pads were changed at around 50k miles.
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
It might just be the disc edge catching. They get a lip when they wear a bit. Get your grinder and take the lip off see if that does anything for it.
Threads: 20
Thanks Given: 2,126
18
Try cleaning,copaslip & champfering pad edges.
Strawberry flavoured windows
Thanks Given: 44
5
Cheers for that. Cit garage will probably want to fit new discs/pads at next service witch is better than new caliper.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
19-11-2016, 08:24 PM
(This post was last modified: 19-11-2016, 08:31 PM by Col.)
Ron. FYI
Copaslip is old hat now. Ceramic grease is the way to go. Copper grease contains metal and It was found that galvanic corrosion was occuring on aluminium calipers. It can also interfere with abs.
The following 2 users say Thank You to Col for this post:2 users say Thank You to Col for this post
• brajomobil, ron
